Voip Template will not show up.
Discussion in 'Windows' started by sorebuttcheek, Mar 5, 2016.
  1. sorebuttcheek
    Mar 5, 2016
    Hi all,
    Bit of a noob here,
    I been trying to get a voip template to show up.
    I have copied the .pv.xml and .png files to C:\ProgramData\3CX\Data\Http\templates\provider
    restarted all services, waited 3 minutes and relogin.
    tried restarting server
    tried installing 3cx on another machine. and repeating above steps.
    it just refuses to show up
    the files can be found here, maybe there not compatible with the latest version of 3cx?
    https://www.australianphone.com.au/supp ... 7-3cxphone
    Cheers.
    sbc
    10,371
    230
    I assume you are using Version 14? There may very well be some incompatibility. I would contact them to ask if the files have been tested to work with the most recent version of 3CX (if not then they need to update their website), and if the location, where the files are to go, is still correct.
  3. sorebuttcheek
    Mar 5, 2016
    I have just also tried editing the RegistrarHost on a existing template. and restarting services and restarting machine.
    the change does not update.
    I have confirmed the directory on 3cx website
    http://www.3cx.com/blog/docs/voip-provider-template/
    I'm lost on this?
  4. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    It is likely in the wrong place.. I derped when v14 moved where custom phone templates go now.
    x:\ProgramData\3CX\Instancex\Data\Http\Interface\Provisioning\quertyuiop\CustomTemplates\phones
    My phone customization landed under Phones.. which "Phones" also appears to be based at C:\ProgramData\3CX\Data\Http\Templates\phones.. a peer to "Provider".
    Thus, my guess would be you need to drop your template into x:\ProgramData\3CX\Instancex\Data\Http\Interface\Provisioning\quertyuiop\CustomTemplates\provider
    The link to that support doc does look like pre-14.. things moved again with 14 as always (multi-tenant).
    I suppose that may also mean that such customizations are tenant/instance-specific.. didn't think of that until now but yeah.
    If I wanted to ITSP, I'd might like some global custom templates available..
  5. leejor
    10,371
    230
    Perhaps there is something (incorrect?) in the xml file that causes it to show up somewhere other than under Australian providers. Although, if I had to guess, I would think it would be this... <description>AU</description>
    Sorry, posted this before I had seen Ian posted the same suggestion.
  6. ian.watts
    Apr 8, 2011
    532
    Correction and update:
    I dropped those two files here:
    C:\ProgramData\3CX\Instance1\Data\Http\Templates\provider
    And I saw it show up on our page to add a new trunk provider.
    No restarts were necessary.
    Removed them from that folder.. checked again.. no more Australian Phone Company.
    Great.. now Beds Are Burning is playing in my head..
  7. sorebuttcheek
    Mar 5, 2016
    Thanks Ian,
    working now.
