VoiP testing tools
Discussion in '3CX Phone System - General' started by Michael Knutson, May 5, 2017.
  1. Michael Knutson
    Feb 20, 2017
    16
    Look for some advice from others. What tools are you using to test VoIP quality in regards to bandwidth both internal and external? We would love to be able to look at latency and jitter over a period of time.
  2. 12494
    12494 Member
    Apr 16, 2010
    306
    31
    pingplotter
  3. datamerge
    datamerge New Member
    Nov 19, 2014
    181
    25
    Myconnectionserver.com
    Expensive, but good. Also Mikrotik routers have good tools like traffic generator.
