VOIP trouble
Discussion in '3CX Phone System - General' started by mylove4life, Feb 20, 2012.
  1. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    Hi guys, I am having trouble with my VOIP provider and the internet. I have Comcast and their highest price cable modem and I still have trouble with it breaking up and sometimes it will just downright not work. I have tracked the problem to just the internet itself.
    My question is, is there anyone using Comcast's business telephone lines? And what would you guys recommend for hardware to connect them into the 3cx phone system.
  2. willow
    willow Member
    Mar 1, 2011
    471
    I have alot of customers on Comcast business lines using everything from a grand stream ht503 to sangoma cards. I oerfer the sangoma cards because f the all in one appeal but they are more pricey then grand stream.
  3. mylove4life
    Jan 7, 2010
    165
    Is there a sangoma card you like that best?
  4. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Have you not used VoIP Gateways? I have two csutomer using Comcast voice lines and Patton Gateways no problems whatsoever. The only reason I'd go with Patton over the Grandstream is the support, Patton support is head over heels on Grandstream when it comes to support and just a better product (also alot pricier) On a side note I use a Comcast provided router at my home I used when demoing 3cx a N150 and the call quality was fine however I was using a Cisco Catalys 1950Switch that does provide QoS that was only like $25 used.
  5. mylove4life
    Jan 7, 2010
    165
    Nope, never used one. But it looks like I will have to go that route to get the call level to what it needs to be.
  6. jpillow
    Jun 20, 2011
    1,342
    I would defiitely go that route if first just upgrading your bandwidth doesnt work, no need to buy an entirely new piece of hardware and upgrade to a more expensive service if adding additional bandwidth will get the job done. If your current ISP has a higher bandwidth package give it a try before going the other route. Let me know what happens, thanks!
  7. mylove4life
    Jan 7, 2010
    165
    I would do so, but I have a 30Meg up/down Bus class Comcast cable modem. The problem is just the internet hops that the system needs to get to the VOIP provider.
  8. jpillow
    Jun 20, 2011
    1,342
    If the problem is the amount of hops to the VoIP provider it sounds like you may want to go with a hardline. Its a bit more but at the end of the day if it eliminates your voice issues its definitely worth the cost.
