VOIP Trunk shows call that does not exist
Discussion in '3CX Phone System - General' started by lonestar.computer, Feb 17, 2008.
  1. lonestar.computer
    Jan 27, 2008
    16
    A call shows to be in progress that does not exist. There is no way to clear all calls, or clear this one call. I am using Broadvox as the SIP trunk provider. Every night the PBX hangs and will not accept calls until the server is rebooted.
    Is this normal?
  2. landfiets
    landfiets New Member
    Jul 17, 2007
    243
    Re: VOIP Trunk hangs - shows call that does not exist
    With new update everyhting should be fine !!
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,007
    309
    Lonestarcomputer,
    Please check if on your computer the firewall check is able to complete successfully without warnings or errors. If yes, please let us know in more detail the exact error you are getting and when it happens.
