VoipBuster Help
Discussion in '3CX Phone System - General' started by jay007, Feb 23, 2010.
  1. jay007
    Feb 23, 2010
    Hi I am using Voip Buster to test 3cx but cant get it to work. When I dial a number Some guy comes on and says
    " You Have dialled an invalid Number please make sure your call always starts with 2 zeros country code and subscriber for more information please check our website"
    I am dialing an Irish number so I am dialing 00353 and droping the 1st digit. If i dial it from Voipbuster it work ok. Wonder if its the outbound rules I have wrong.
    Here is my outbound rules
    Calls to numbers strating with (Prefix) = 00353
    Calls from extesion = 100
    Calls to numbers with length = 14
    Make outbound calls on
    Route 1 Voipbuster
    Strip digits 5 and prepend is blank
    10,563
    245
    It sounds like you shouldn't be stripping off any digits if they want to receive two zeros and all of the remaining digits.
  3. StaffKB
    Jan 5, 2010
    97
    With your setup... If you dial 00353123456789.... The called number woud be "123456789" strippong the 00353
    An inbound rule which will state all calls going out pass through xxx (Generally used with people who have one voip provider or pstn line)
    Calls to numbers strating with (Prefix) = 0,1,2,3,4,5,6,7,8,9
    Calls from extesion = (LEAVE THIS BLANK)
    Calls to numbers with length = (LEAVE THIS BLANK)
    Route 1 : Your Voip Provider or PSTN Device
    Strip digits = 0
    Prepend = (LEAVE THIS BLANK)
