VoipBuster / Voipcheap .API
Discussion in '3CX Phone System - General' started by jvwelzen, Aug 21, 2008.
  1. jvwelzen
    Jun 9, 2008
    8
    I found an .api for voipbuster on the astriks forum
    I was wondering if it is possible to use it with 3cx below is the scipt
    on astriks you can call 301 for example en then hear your balance of your voipbuster account
    here is the script
    <?php
    function encryptString($string) {
    for($i=0; $i < strlen($string); $i++) {
    if(is_numeric($string[$i])) {
    if($string[$i] < "5")
    $string[$i]= $string[$i] + 5;
    else
    $string[$i]= $string[$i] - 5;
    return str_rot13($string);
    // Set username and password
    $username = encryptString($login);
    $password = encryptString($pass);
    $LOGINURL = ('https://myaccount.voipcheap.com/clx/index.php?part=plogin&username=' . $username . '&password=' . $password);
    $CREDITURL = 'https://myaccount.voipcheap.com/clx/buy_credit.php';
    $user_agent = "Mozilla/4.0 (compatible; MSIE 5.01; Windows NT 5.0)"; // <- nieuw!!!!
    //curl init
    $ch = curl_init();
    // SET 1st REQUEST
    curl_setopt($ch, CURLOPT_URL, $LOGINURL);
    curl_setopt ($ch, CURLOPT_RETURNTRANSFER, 1); // <-nieuw!!!!
    curl_setopt($ch, CURLOPT_SSL_VERIFYHOST, 0);
    curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, 0);
    curl_setopt($ch, CURLOPT_FOLLOWLOCATION, 0);
    curl_setopt($ch, CURLOPT_HEADER, 1);
    //curl_setopt($ch, CURLOPT_USERAGENT, $user_agent); // <- nieuw!!!!
    //curl_setopt($ch, CURLOPT_COOKIEJAR, $cookies);
    curl_setopt($ch, CURLOPT_COOKIEJAR, '/tmp/cookie.txt');
    // EXECUTE 1st REQUEST (FORM LOGIN)
    $store = curl_exec ($ch);
    //echo $store; //Only for debug
    // SET 2nd REQUEST
    curl_setopt($ch, CURLOPT_URL, $CREDITURL);
    // EXECUTE 2nd REQUEST (CREDITURL)
    $content = curl_exec ($ch);
    // CLOSE CURL
    curl_close ($ch);
    //echo $content; //Only for debug
    //we gaan eventjes knippen in de ruwe source code van de returnwaarde
    //bestudeer de html source en alles wordt duidelijk
    $start = strpos($content,'balanceid'); //bepaal start van balanceid
    $start1 = strpos($content,'Freedays remaining:'); //bepaal start van balanceid
    $deelstring = substr($content,$start+14,26); //kopieer het begin van het bedrag de string naar een tussen waarde
    $deelstring1 = substr($content,$start1+26,10); //kopieer het begin van het bedrag de string naar een tussen waarde
    //print $deelstring; //Only for debug
    $einde = strpos($deelstring,'<'); //einde van het bedrag is waar de afsluit tag begint
    $einde1 = strpos($deelstring1,'<'); //einde van het bedrag is waar de afsluit tag begint
    $bedrag = substr($deelstring,0,$einde);
    $bedrag1 = substr($deelstring1,0,$einde1);
    //echo "$content";
    print $bedrag;
    echo " Euro ";
    echo "<br><br>";
    If ($bedrag1 == NULL){
    echo '0';
    echo " Dagen ";
    } else {
    print $bedrag1;
    echo " Dagen ";
  2. francesco
    francesco New Member
    Jun 23, 2008
    102
    for me, 3cx don't permit to call a script
