Voipbuster, Webcalldirect Outbound Caller ID
Discussion in '3CX Phone System - General' started by cwelle, Jan 8, 2010.
  1. cwelle
    Dec 16, 2009
    18
    Hi, there..
    I managed to configure 3CX to use Voipbuster and Webcalldirect as VoIP provider.. One thing that i am not able to configure is my OUTBOUND caller id for externals calls.. For exmpl i have confirmed this number in Voipbuster application: 001234567 and i am able to use it if i use Voipbuster main Windows app, as my caller id.. The same story is for Webcalldirect also..
    When i set that numer in EXTENSION properties (Other options) the phone number that i see as my caller id is some +2123123.. Not even close to what i have!
    Is there any other setting that i am missing?
    Thnx in advance..
  2. blue7
    Sep 14, 2009
    5
    Edit VOIP Provider >> Outbound Parameters
    Add
    Sip Field >> From: User Part
    Variable >> Custom field
    Custom Value >> "confirmed phonenumber"
    With regards,
    Ron
  3. cwelle
    Dec 16, 2009
    18
    Is there anyway that i can thank you?? :)
    U are great!!! Worx as a charm! :)
