Voiptalk not supported anymore?
Discussion in '3CX Phone System - General' started by larteyc, May 11, 2016.
  1. larteyc
    Dec 3, 2015
    Hi all,
    Was doing sometesting pre to going live and I am getting the following now with my SIP trunk :
    [​IMG]
    can anyone confirm if this is true as we are currently going through Draytel and they are part of voiptalk.org.
    Cheers
    Chris
  2. Cjay
    Cjay New Member
    Feb 24, 2007
    198
    I just ignore this message - I get the same with Voipdiscount but it continues to work just fine!
    Chris
