Voptech VG1081 8 FXO gateway
Discussion in '3CX Phone System - General' started by JVH, Aug 27, 2009.
  1. JVH
    JVH
    Apr 25, 2007
    18
    Hi All,
    I am trying to set up an auto attendant and voicemail system using some ports in our current pbx.
    Does anyone have any experience with this Voptech VG1081 8 FXO gateway?
    http://www.voptech.com/product_view.asp?tid=43&id=136
    I am basically looking for a low cost FXO gateway with at least 4 ports.
    But since we will eventually convert to 3CX as a full VOIP pbx and we have 8 pots lines an 8 port model is being considered.
    John
  2. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    Never heard of their products before. Let the adventure begin..
