Solved Vozelia : Certified SIP Trunk
Discussion in '3CX Phone System - General' started by telis, Jun 23, 2017.
  1. telis
    telis New Member
    Aug 13, 2007
    147
    21
    I am trying to set up 3CX to use a Vozelia Telecom SIP trunk, I chose vozelia.com because it is 3CX certified – we are a 3CX partner.
    I have two problems:-
    1. The 3CX SIP Trunk does not register unless I change the host from sip.vozelia.com as it is in the certified template to sip.proxy.vozelia.com as it is in the email vozelia have sent with the account details. sip.vozelia.com is a CNAME that points to sipdir.online.lync.com so I can’t see that accepting PSTN calls??
    2. If I change the SIP server in the Vozelia template from sip.vozelia.com to sip.proxy.vozelia.com the trunk registers and can make and receive calls. However the outbound called ID is always the vozelia username (which is not a PSTN number) instead of what I specify in 3CX even if I specify the number Vozelia assigned as the DDI.
  2. telis
    telis New Member
    Aug 13, 2007
    147
    21
    This is now resolved.
    1. Be aware that according to Vozelia support the 3CX certified template is out of date, and you need to use sip.proxy.vozelia.com as the host. Maybe 3CX can fix this.
    2. The caller id was a config. error at Vozelia's end that was fixed by Vozelia support pretty promptly.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    Glad the issue is resolved and thank you for the info. I will pass it on to the appropriate department.
