VPN for Wifi enabled mobile to access blocked voip in UAE?
Discussion in 'Windows' started by shaunstevin, May 17, 2012.
  1. shaunstevin
    May 16, 2012
    9
    hi,
    today the voip has become resonable and affordable, but unfortunately the ISP here in UAE has blocked the voip access. there are many VPN alternatives for PC to access blocked VOIP but for my Wifi enabled Nokia to access blocked voip there is not even a single VPN i could find after constantly googling for many days. i would be greatly obliged if anyone could suggest me a solution.
    11,277
    360
    Re: VPN for Wifi enabled mobile to access blocked voip in UA
    I'm not sure exactly what sort of service offering you are hoping to find, but this sort of thing (VoIP restrictions by governments/ISP's) has come up before. This post, may, or may not, be of help with your particular problem. http://www.3cx.com/forums/voip-provider-blocked-voip-blocked-by-isp-23055.html#p117091
