VPN on Cloud 3CX
Discussion in '3CX Phone System - General' started by AH2, Feb 7, 2018.
  1. AH2
    AH2 New Member
    Mar 14, 2017
    112
    I have a Loca Trunk Provider that will only allow me to connect to the Trunk via IP authentication, so they provided us with some VPN credentials, can anyone please point me in the right directo to configure this VPN to the 3CX server hosted on Google Cloud ?
    Thanks in advanced.
    AH
  2. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    930
    150
    Not a 3CX question and unless someone has worked with your provider (which you didn't name) it's possibly specific to your provider. So I would check this link and talk to your provider who is the other end of that VPN.
    https://cloud.google.com/vpn/docs/how-to/creating-vpns
    AH2 likes this.
  3. AH2
    AH2 New Member
    Mar 14, 2017
    112
    Thanks for the reply, the provider its ETB a Local Telecom Company in Colombia.
  4. cobaltit
    Mar 22, 2012
    930
    150
    Not one I'm familiar with. Interesting that they require a VPN for their IP authenticated trunk. I would confirm with them whether the VPN is optional or required. If required just try following the link I provided on creating a VPN, pop the credentials in that they gave you and you may get lucky.
    Good luck!
    AH2 likes this.
  5. AH2
    AH2 New Member
    Mar 14, 2017
    112
    The VPN It's not a requirement for that provider if the Server it's on the premises, but to be on the Cloud it is, we need to setup that VPN on the 3CX Server to be able to authenticate.
    I will try your tip and see how it goes, thanks.
