VPN or Proxy Manager
Discussion in '3CX Phone System - General' started by neon013, Dec 16, 2013.
  1. neon013
    Dec 16, 2013
    If I have sites connected via a VPN (via Draytek routers) do I need to use to use 3CX proxy manager to connect the sites?
    I am assuming the proxy manager will then need a machine permanently 'on' to make calls - is this correct?
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Do you "need/have" to use the SPM, the answer is no you do not have to use the SPM. It will boil down to whatever works best for you and your personal preferences when implementing and using either VPN or SPM
  3. leejor
    11,126
    330
    VPN has encryption, the 3CX Proxy Manager does not. The proxy manager allows remote sites, with more than a couple of sets to "work properly" but offers no security, if that is a concern. And, yes, it is required to run on a PC, at the remote end.
  4. bardissi
    bardissi Member
    Jan 31, 2012
    318
    NEITHER!!!
    Session Border Controller for all Remote phones.
    We have thousands of extensions on the WAN connected back to 3CX servers using an SBC.
    Works great.
  5. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Hi bardissi,
    FYI, "3CX SIP/RTP proxy manager" IS and always WAS a "Session Border Controller"...
  6. bardissi
    bardissi Member
    Jan 31, 2012
    318
    Sure but my SBC doesnt need anything installed on the REMOTE SITE!!!!!!
    Critical fact!
  7. SY
    3CX Support
    Jan 26, 2007
    1,825
    Then... you can remove this SBC because 3CX PhoneSystem does not require any help :)
  8. bardissi
    bardissi Member
    Jan 31, 2012
    318
    Haha totally disagree but that's OK!
  9. SY
    3CX Support
    Jan 26, 2007
    1,825
    Same "haha" on my side ;)
    Please show the case where "SBC", you mentioned, helps 3CX Phonesystem to work properly with remote extensions...
  10. bardissi
    bardissi Member
    Jan 31, 2012
    318
    I have 60 cases
    3 multitenant servers all remote phones
    No 3cx proxy manager at any remote site
    No stun
    No VPN
    No manually opening up ports for individual phones
    Drop ship from distributor fully provisioned
    Customer plugs phones in at any remote site
    We don't have to touch any nat settings on any customer routers or firewalls
  11. tsukraw
    tsukraw New Member
    Mar 9, 2012
    190
    7
    What device are you referring to being used?
  12. bardissi
    bardissi Member
    Jan 31, 2012
    318
    No device... SBC in the cloud as a service...
    Direct message me if you want me info
  13. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    SY, let me keep you company with the HAHAHA. Bardissi is simply over-complicating this. Positively no need for an SBC neighboring 3CX, maybe at the remote site. But the SIP Proxy Manager is a very effective SBC.
    Anyway, back to the very simple original question, if you already have a site-site VPN you are perfectly fine. No need for STUN, SIP Proxy etc.
    Bardissi, please READ the question, he HAS already a SITE-SITE VPN.
  14. bardissi
    bardissi Member
    Jan 31, 2012
    318
    No worries Charles everyone can go about this however they want.
    We tried site-to-site vpn vs SBC and found that things didn't quite work as well.
    @ the end of the day the route needs enough horsepower to handle that kind of traffic via VPN.
    So if they are only doing a hand full of phones and the routes at each end are workable that will work sure.
    But any type of volume across that VPN may not be a very good story.
  15. sigma1
    Nov 20, 2009
    542
    Bardissi:
    In IT there are many ways to reach the goal. The best way is always the one with the least number of components and the most simple. He should leverage what he already as in place and working well. If hos routers lack horsepower to handle the VPN, and NOTE that he did NOT specify if he is using encryption, maybe he is not and maybe he has a 4-5Mbps circuit so it would be irrelevant. The bottom line is that he needn't any SBC or complicated Enterprise level hardware with added administration work and an additional single point of failure. Keep it simple... works every time. With 198 hosts in our data center (hosts not VMs, notice), we do not use any SBC. Those are for applications where the network engineer is not very capable and needs an easy way to secure the backend and make $$$ with extra labor time. We have thousand of remote extensions, not one Proxy manager nor SBC.
  16. bardissi
    bardissi Member
    Jan 31, 2012
    318
    Seems like we are on two different pages on what goes into an SBC and that's ok.
    The SBC requires 0 maintenance and 0 extra work to be extremely honest.
    All it means is using a different dns / ip enter when going to provision the phones via the 3CX management console using the "Remote extension SIP Proxy Manager Mode"
    That's it!
    It really cant be any simpler and removed any need for us to mess with customer routers / firewalls, worry about a windows machine going down and the 3CX proxy manager going down with it.
    I totally agree with you that the more simple the deployment and roll out the better it is for everyone!
    With the SBC option we saw not only a super simplification of the whole process the deployment time went down as well. No need to deal with massive amounts of firewall rules to port forward for individual phones.
    Glad you are doing well with your process however if we had to go through the rest of the 14,842 extensions that we are migrating to 3CX out of 18,931 in totally by jumping through more than a provisioning URL and a drop shipment we wouldn't be using 3CX !
  17. sigma1
    Nov 20, 2009
    542
    Bardissi:
    All of our phones ship with only one change... the Server Config File path... Once the client plugs them in they are in business after 1 automated reboot. I truly fail to understand what your SBC has to do with any of this. Sorry, we have just been doing this since.... 1995. As 3CX tech support will verify with you, 99.9% of all remote extension issues reside at the remote end router and their NAT issues. This has NOTHING to do with an SBC neighboring 3CX. Please quit while you are ahead. You have an SBC to isolate your 3CX infrastructure from the outside world at best for security reasons. You can google back and we sustained several massive DOS attacks etc., against our 3CX infrastructure, 3CX did AWESOME with no issues whatsoever and all by itself. 3CX rules!
  18. bardissi
    bardissi Member
    Jan 31, 2012
    318
    Security reasons has nothing to do with why we use an SBC.
    And to be clear we operate out of 4 geographically seperated data centers and on top of that still use the SBC for on prem deployments where remote phones are needed.
    Sounds like your idea of experience of sbc's vs what we are actively doing today are not in the sane boat.
    We actually have a dozen other 3cx partners actively using our SBC with their customers and love it.
    I feel like if you actually tried it you would prefer the simplicity in it.
    Offer is open free of charge for you to send over a public IP that we can whitelist and then send you the info to test with your 3cx server at your facility
  19. sigma1
    Nov 20, 2009
    542
    Bardissi:
    Thank you for the offer, we operate 17 world class data centers and we provide service to hundreds of SIP providers. I think we are very happy with our services. Further, I think we are vastly different in technical know-how, size, scope and sophistication yet we love to keep things simple and reliable without unnecessary devices to interject latency and to manage. 3CX can do the job all by itself and very well too. Would you be interested in US or International routes? We have terrific deals on 10MM minute bundles all on private 10GbE Fiber peered with Tier 1 carriers from Level3, Verizon to Comcast etc. Just $19,000 now.
    All the best!
    Charles
  20. bardissi
    bardissi Member
    Jan 31, 2012
    318
    Unfortunately you wouldn't be offering any value to us.
    By the way Charles your reputation proceeds you.
    Nice to meet you but seriously you need a bottle of something.
    What is your drink of choice I will ship you a christmas present.
