Solved VPS Linux - Install - Firewall
Discussion in '3CX Phone System - General' started by ittogo, Feb 10, 2017.
  1. ittogo
    Feb 24, 2011
    13
    Hi There,
    we tested a virtual pbx hosted by OVH and this works great.
    https://www.3cx.com/docs/virtual-pbx-ovh/
    Our problem is the firewall on the linux system. In general all ports are open on the VPS server.
    I try to make a script for iptables and it seemd to work. Calls inbound/outbound, STUN all is working.
    But the firewall checker does not work.
    So, i was wondering if anybody has a working script for iptables, where the firewall checker and everything is working.
    Unfortunately 3CX does not provide a script.
    Thanks in advance.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
  3. ittogo
    Feb 24, 2011
    13
    we used the installation provided in my link.
    Is there any chance that you can give me the iptables?
    Best regards
  4. ittogo
    Feb 24, 2011
    13
    Hi there,
    i got the iptables form the linux ISO and could successfully restore them into my cloud pbx.
    Now the firewall check is working fine.
    Best regerads
  5. YiannisH_3CX
    May 10, 2016
    4,349
    274
    Glad to hear it is working now
  6. SystemWise
    Dec 12, 2014
    6
    Hello YiannisH,
    We have also set up a test virtual pbx on OVH and this thread brings up quite a good question. As OVH provide the ISO for these virtuals is there anything else from the 3CX ISO, like the aforementioned firewall rules, that need to be "tweaked" after we have built the phone system?
    I look forward to hearing from you.
    Tony
    P.S. Ittogo, any chance you could document how you extracted and applied the firewall rules?
  7. SystemWise
    Dec 12, 2014
    6
