VPS Server Recommendations
Discussion in '3CX Phone System - General' started by altitude, Nov 15, 2015.
  1. altitude
    Nov 15, 2015
    26
    We have just purchased a 3CX 8 sim call licence and set it up on an Amazon VPS and it is working great with the exception of the call quality. After some searching we found another person who had the same issue with an Amazon VPS.
    We obviously need to move to another VPS provider to gain the desired high call quality.
    Could anyone here give some recommendations/suggestions? We are wishing to keep the server costs reasonable.
  2. argenvoip
    Sep 19, 2011
    14
    Hello, I do not speak English, I use translator.
    that instance you use? I use AWS t2.micro 3cx 4SC, smooth audio. What is the audio problem? you cut? Poor quality?
    others are recommended OVH VPS
    3CX uses them to host their services and hosted 3cx webmeeting
    Greeting!!
  3. altitude
    Nov 15, 2015
    26
    At present we have it on a AWS t2.micro and audio quality is poor. I can PM you a number so you can here it if you wish.
    I'll have a look at OVH.
  4. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    We have many systems on AWS and have never had call quality issues at all.... What exactly are you experiencing?
    Which type of instance are you using?
  5. argenvoip
    Sep 19, 2011
    14
    Hi Altitude, t2.micro only has 1 GB
    To 3cx 8SC, you need 2GB
    But what is the problem?
    1 call is poor?
    My 3cx installed in t2.micro, with 3 concurrent calls and WebRTC audio recording works well
    Saludos!!
  6. altitude
    Nov 15, 2015
    26
    Thanks all for you replies.
    I have now got it working fine now. There were a few things overlooked during the setup that impacted the call quality including:
    - ensuring the codecs were set correctly between each SIP trunk and 3CX
    - choosing the SIP point closest to the 3CX server
    - ensuring the digital receptionist audio file was in the right .wav format (don't use Audacity as its incapable of saving the file correctly)
  7. 3cxBora
    Jun 17, 2015
    36
    Anyone use 3cx cloud server in ESXi VM environment without any call quality or other issues?
    TIA for your input, and Happy New Year,
    Bora
  8. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    We deploy all our 3CX PBXs via our cluster processing 60,000 calls per day with no issues.
  9. 3cxBora
    Jun 17, 2015
    36
    Dave, are you saying you are running on 3cx v14 Virtual Instances in ESXi Cluster with iSCSI SAN?
    What type of drives - 15K SAS, SATA or SSD? CPU are allocated?
    What is your spec because 3cx does provide much details?
    How do handle fail over?
    Thank you for feedback and sharing,
    Bora
  10. davidbenwell
    Apr 27, 2010
    704
    We run each PBX on a Virtual Windows 2012 R2 Server
    4 x Servers in a HA / DRS Cluster
    Server Spec - Each Server in the cluster
    2 x Intel Xeon E5-2650 CPUs (shows as 32 Logical Processors per server
    128GB Ram
    Each server is connected to two Independent San Switches via two 10gbps feeds. Our QSan P600Q-D424 is then connected two each of the San Switches via 4 x 10Gbps Network Feeds. 2 per switch.
    each disk in the SAN is a 300GB 15K SAS disk
    By default, we allocate 1 vCPU core per server
    Each Server has a 1Gbps Network cable to the Internet Switch
    Each Server has a 1Gbps Vlan for Veeam Backups and Vcentre Heartbeat
    Each server has 2 x 10Gbps Network Cables going to two Independent Netgear 10Gbps Switches.
