VVX410 and 3CX V15
Discussion in '3CX Phone System - General' started by edbroaddus, Aug 31, 2016.
  1. edbroaddus
    Aug 31, 2016
    So far I have read everything I can find on provisioning a Polycom VVX410. I can't get them to provision even if I specify it manually in the web interface for the phone. I am only using this for testing but I'd like to get it working if possible. I can connect windows clients fine so the server seems to be working.
    000336.971|cfg |4|00|Prov|Server did not respond to request for file 0004f2c5xxxx.cfg
    000336.971|cfg |4|00|Prov|Server '10.0.5.xx' is unresponsive
    000336.971|cfg |4|00|Prov|Download of master configuration file failed
    000336.971|cfg |4|00|Prov|Trying to boot from existing configuration
    000336.972|cfg |4|00|Prov|Provisioning failed
    000336.975|cfg |*|00|Prov|Finished updating configuration
    From my phone logs.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,455
    355
    Please specify the following:
    what firmware is your Polycom on?
    Have you tried provisioning other IP phones except polycoms?
    I have a Polycom vvx500 here and what i do is set up the extension in the management console copy the provisioning link generated there, then go to the web interface of the phone and under settings >>provisioning server i select server type http, copy provisioning link in the server address option and leave the server user and server password empty.
