W52P "make call"
Discussion in 'Windows' started by du15, Jul 10, 2015.
  1. du15
    Jul 10, 2015
    Our company is new in the 3cx voip business and
    we use all w32g. If you make a call over 3cx softphone for windows, the first time you had to accept that it is allowed to make calls over the software. This worked fine.
    But with the W52P, this function always comes on. Every call i make, first my W52P rings after i've accepted to make a call, the call goes out...
    Those anyone know how to make it accept automatically ?
    Thanks ! :D
    Best regards
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    815
    49
    This is a correct behaviour.
    The W52P does not accept HTTP commands like the other Yealink phones do.
  3. du15
    Jul 10, 2015
    Hmm okey, thank you for your help :)
