Implemented W52P Provisioning of additional identities
Discussion in 'Ideas' started by brendan.helsham, May 11, 2016.
  1. brendan.helsham
    Jan 23, 2008
    35
    5
    We need a way so that we can auto-provision all 5 possible identities in the W52P base station. Currently, you can provision the first identity and the additional 4 have to be done manually.
  2. DSXDATA
    DSXDATA New Member
    Oct 20, 2015
    170
    58
    There is a work around for this: modify the template to use the BLF's to set the identities. In order for that to work, all extensions have to have the same password - but otherwise its a viable solution.
