Waiting time for transferred call to voicemail diversion
Discussion in '3CX Phone System - General' started by sohc, Mar 4, 2014.
  1. sohc
    Apr 22, 2009
    24
    When I transfer a call to another local number it takes almost a minute before it goes to their voicemail.
    How can I reduce this? In my config below it is only 25 seconds. I believe there's an XML file that I need to edit to change the waiting time.
    This is my setup
    [​IMG]
    10,360
    226
    Is this a blind, or attended transfer? Not that it should make much of a difference, but if only one type had the excessive delay, then that might point to what is happening.
    Have you looked over the 3CX log of the call to see at what point the delay occurs, or, if there is anything to indicate why it takes so long?
