WALIA - SETUP ASSISTANCE NEEDED
Discussion in '3CX Phone System - General' started by waliaz, Aug 10, 2011.
  1. waliaz
    Aug 9, 2011
    Hello all,
    I need assistance in understanding if my setup is correct.
    Scenario:
    Main office with 3 users
    3 Remote offices with 2 users
    The main aim of the 3CX system is to have free intra office calls.
    my remote users can connect to the server and the extension status shows 'registered' and their phone shows 'on hook' and available
    but when a call is initiated, the extension status on the 3CX server shows as dialling but the call never reaches the extension dialled.
    It works perfectly fine in main office locally.
    I need to understand a couple of things:
    How do I setup remote extensions
    The local extensions 'other tab' shows the extension as logged out even though they are online and connection. How do I enable that?
    Regards,
    Kuldeep
  2. willow
    willow Member
    Mar 1, 2011
    471
    you need to look at the 3cx proxy manager config guides. for the remote site.
  3. waliaz
    Aug 9, 2011
    Thanks for your reply. Will check that out this evening.
