Wallboard Add
Discussion in 'CRM / Helpdesk / App Integration' started by Schrodz, Dec 7, 2017.
  1. Schrodz
    Schrodz New Member
    Apr 21, 2017
    100
    14
    We use the normal wallboard which is great. I was wondering if it was possible for us to create another small box That shows "Agents Available" I have seen a post using C# but how would we add it so it connects to 3CX and then displays the output that we require.
    Kind Regards,
    Daniel Schroeder
  2. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    258
    12
    Hello @Schrodz,
    Follow this blog post you might find a solution of your problem
    Thank you
