Wallboard - agents servicing the queue
Discussion in 'Ideas' started by Joakim Ribb, Feb 19, 2018.
Wallboard - agents servicing the queue 5 5 3votes
5/5, 3 votes
  1. Joakim Ribb
    Feb 19, 2018
    7
    For many callcenter managers, the amount of logged in users to a queue is vital to know.
    Adding a field or adding information to the field "Agents busy" regarding how many agents are logged in woudl add great value.
    Example: "4/3 agents busy" would solve the problem easily (I think most customers can accept that this will only work correctly if you have one queue showed).
    B.r
    Joakim
  2. PaulD
    Jul 4, 2010
    90
    11
    +1
