Wallboard blank - "Connection Closed"
Discussion in '3CX Phone System - General' started by TSlocum, Nov 3, 2015.
  1. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    16
    I have a user trying to access the Queue wallboard and it shows nothing under each category and on the top left it says "Connection closed."
    Any idea what could be causing this?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,586
    309
    What version and SP version?
  3. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    16
    3CX v12.5.44178.1002 SP2
    It works fine for me on my workstation. The user tried it in Chrome and IE.
  4. craigreilly
    Feb 1, 2012
    3,586
    309
    compare versions of browsers, firewall (not likely), pop-up blocker?
    I would reset the Browser to default and see if it helps.
  5. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    16
    Updated browser fixed it. Thanks.
