wallboard - not working remotely
Discussion in '3CX Phone System - General' started by minijay, Sep 2, 2015.
  1. minijay
    Jan 3, 2009
    9
    Hi There
    were running v12.5 and have just upgraded to the pro version.
    im trying to get the wallboard running but i cant seem to get it to work remotely.
    ive opened it on the 3cx server and its working fine but for some reason when i try to connect to it remotely it doesnt display any statistics.
    when i go to http://serverdomain:5000/Wallboard/default.aspx i get the login screen so i login as i would on the 3cx and i get the wallboard display but the top left message shows connecting to server and it never seems to.
    i did a search and found that i need to open port 4516 which i have now done but it hasnt made any changes... ive tried connecting on port 4516 but i get a page error..
    is this port correct or have i missed something else that i need to do
    many thanks in advance
    justin
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi Justin,
    Opening the port should have done the trick, please open a ticket on our support portal so that this can be investigated further.
  3. minijay
    Jan 3, 2009
    9
    hi pj3cx
    thanks for getting back to me
    im using IIS would that have any effect on things ?? i restarted the 3cx services but that hasnt helped so at a loss
    i would open a ticket but i cant seem to be able to... we have support and maintenance but none of my emails seem to be registered so i cant see how i can open a ticket
    what can i do to get this sorted...
    thanks
    justin
  4. minijay
    Jan 3, 2009
    9
    my bad
    turns out we only had maintenance and not support. not sure why this had lapsed but sorted now.. ill submit a ticket shortly
    thanks
    justin
  5. minijay
    Jan 3, 2009
    9
    Re: wallboard - not working remotely - SOLVED
    just an update
    we managed to solve the problem turned out that our router was not forwarding the port on the right address. we have a number of external IP's in our router and for some reason it had defaulted to the first address instead of the one used by the phone system.
    all changed and working now
    justin
