Wallboard remains empty (N/A)
Discussion in '3CX Phone System - General' started by Ralph Ootevaar, Jan 18, 2017.
Tags:
  1. Ralph Ootevaar
    Jan 18, 2017
    5
    Hi, we have the pro license of 3CX running, we have queues, everything is working fine.
    I want to bring the wallboard on the screen in the room, but somehow the board remains empty. Everything says N/A except for date and time.
    I pressed the cog button and selected the queues.
    I tried to find how to fix it in the forum and the documentation, but to no avail. What am I missing?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Does that extension have presence? Is the extension member of the queues?
    If you are a member of the queues and the queues are selected from the settings button then it should work.
  3. Ralph Ootevaar
    Jan 18, 2017
    5
    Extension is my own, I'm a member of the queues, and both queues are selected.
    No statistics though...
  4. GiannosC_3CX
    GiannosC_3CX Guest
    Dear Ralph,
    Do you use remote PBX or local? Also, please let us know what version of 3cx phone system and clients are you using?
  5. Ralph Ootevaar
    Jan 18, 2017
    5
    Local pbx (client on my machine, connecting to server over local lan), we run pro version 15.0.0.
    Client version is 15.0.60903.0
  6. GiannosC_3CX
    GiannosC_3CX Guest
    Dear Ralph,
    The problem appears only on one client in your lan?
    Also please check your anti-virus if it blocks the https port. Try un-installing you anti-virus for a test. By default the 5001 port is used, did you change the management console port?
  7. Ralph Ootevaar
    Jan 18, 2017
    5
    We use the default port 5001
    I disabled my firewall, but no changes...
    Also checked on a different machine, same problem. Also checked on the server itself in RDP, doesn't work there either
  8. YiannisH_3CX
    May 10, 2016
    6,016
    421
    Is there any antivirus installed on the PBX server?
  9. Ralph Ootevaar
    Jan 18, 2017
    5
    No antivirus, and the firewall is turned off.
