Wallboard
Discussion in '3CX Phone System - General' started by stash, Mar 1, 2012.
  1. stash
    stash New Member
    Feb 23, 2012
    213
    How can i create another user login for the wallboard so they won't know the admin credentials of my 3cx system?
    Thanks,
    STASH
  2. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    In v10 only the admin of the system can access wallboard. You will be able in v11 to give rights to an extension to access wallboard.
  3. stash
    stash New Member
    Feb 23, 2012
    213
    Sir danhriscanu
    Ok sir thanks for the quick reply.
    STASH:D
