Want to install on a standalone laptop
Discussion in '3CX Phone System - General' started by drotkopf, Jan 13, 2009.
  1. drotkopf
    Dec 31, 2008
    17
    I installed 3CX 7 on a standalone (not connected to any domain) laptop and I want to provision 2 Polycom phones.
    1) Any advice on how to configure? For example, SMTP.
    2) I didn't see any polycom .cfg being created by 3CX. Should they? Should I install a tftp server and manually create the .cfg files?
    Thanks,
    Dan
  2. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    You can only auto provision the phones if you have the paid version.
    Have a look at the support documents for the Polycom's
    http://www.3cx.com/support/
  3. drotkopf
    Dec 31, 2008
    17
    Got it. I'll then install a tftp server on the laptop and manually point the phones to it.
    Now, what about SMTP so that it can send the voice mails? Any link on how to configure an SMTP server on my laptop?
    Thanks.
  4. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    You can either install IIS SMTP on the laptop and configure it to relay to your ISP. If you can send emails via your ISP it will be far easier than having to manage an internal mailserver.
  5. drotkopf
    Dec 31, 2008
    17
    Thanks a lot.
