Wanting 10 Second Delay Before IVR
Discussion in '3CX Phone System - General' started by CirrusTech, Sep 8, 2017.
  1. CirrusTech
    Sep 8, 2017
    Hi!
    This one is going to sound super strange but I have a potential client that wants a 10-second delay before hit the main IVR. Any suggestions on how I could do this with 3CX? Currently running V15.5
  2. AndreasPo_3CX
    AndreasPo_3CX Support Team
    Aug 10, 2017
    138
    12
    Hi @CirrusTech ,
    what exactly do you mean when you say 10-second delay before hitting the main IVR? Do you just want 10 seconds of silence before the IVR prompt (ivr options will be available for the caller to press) or do you want the caller to not enter the IVR at all for 10 seconds?
  3. CirrusTech
    Sep 8, 2017
    Maybe what I meant was before it hits the main AA that it's going into. Basicly, the caller would call the main number > 10 seconds of ring time > then hit the main AA. Is that possible?
  4. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    877
    135
    Only way I can see to make this work
    Create dummy / virtual extension - make sure 'Accept multiple call' is ticked. No answer forward to IVR number
    Forward incoming calls to dummy / virtual extension
  5. jbryant84
    jbryant84 New Member
    Apr 6, 2016
    106
    38
    Much easier than that. Set the inbound rule to a ring group containing one or more phones, then set the destination if no answer on the RG to the IVR. We have this in place with several clients.
  6. AndreasPo_3CX
    Aug 10, 2017
    138
    12
    You cannot leave the call ringing for 10 seconds before it is answered by the PBX but you can definitely simulate this. You just have to create a "dummy" DR which should look something like this:
    1. You leave all the actions to nothing
    2. Set the "Destination for no or invalid input" to 10 seconds->MAIN IVR and If wrong input->MAIN IVR
    3. Set the DR prompt to a ringing tone
