- Joined
- Dec 4, 2017
- Messages
- 12
- Reaction score
- 1
I got the newest 3CX PBX Pro Edition installed on Debian 9. We do have 4 NICs installed, eth0 for WAN and eth1 for LAN. eth2&3 not used yet, and not configured.
eth0: WAN IP
eth1: 10.2.2.1 without default gateway
Extension 251 IP: 10.2.2.3
ISC DHCP Server is running on the system, with option 68 for auto-provisioning. This works perfectly.
Now when I try to call someone, it doesn't matter if it's another extension or an external number, I get the error 499 "Caller is forbidden". Here is a tcpdump from a call that was from extension 251 to 278:
attached text file: tcpdump_caller_forbidden.txt
Here is the log from the 3CX:
Extension 278 is not provisioned via 3CX. It is connected via WAN and just SIP Username/Password. Extension 278 can call 251 but 251 can't call back. 251 can call nothing, not even other auto-provisioned phones. Other auto-provisioned phones can't call neither.
Every phone is a Yealink T46S.
BUT when I use the 3CX Windows Client in Softphone mode, I can call whatever I want.
Do you need any further information?
I just need to know why the 3CX PBS sends the Code 499/"Caller is unknown" and how I can prevent this.
Thank you.
JL
eth0: WAN IP
Code:
12/04/2017 8:38:38 AM - Leg L:13.1[Unknown:] is terminated: Cause: BYE from PBX
12/04/2017 8:38:38 AM - [CM503013]: Call(C:13): Incoming call rejected, caller is unknown; msg=Invite-IN Recv Req INVITE from 10.2.2.3:5060 tid=1091939237 [email protected]:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 10.2.2.3:5060;branch=z9hG4bK1091939237
Max-Forwards: 70
Contact: <sip:[email protected]:5060>
To: <sip:[email protected]:5060>
From: "John Doe"<sip:[email protected]:5060>;tag=298142155
Call-ID: [email protected]
CSeq: 2 INVITE
Allow: INVITE, INFO, PRACK, ACK, BYE, CANCEL, OPTIONS, NOTIFY, REGISTER, SUBSCRIBE, REFER, PUBLISH, UPDATE, MESSAGE
Content-Type: application/sdp
Proxy-Authorization: Digest username="xXxXxXx",realm="3CXPhoneSystem",nonce="414d53595a24fb7e43:90371c13dccee7642933c939f6000206",uri="sip:[email protected]:5060",response="fc5583b28c6a9c9d071b78b8a76d2e1c",algorithm=MD5
Supported: replaces
User-Agent: Yealink SIP-T46S 66.82.0.20
Allow-Events: talk, hold, conference, refer, check-sync
Content-Length: 298
v=0
o=- 20020 20020 IN IP4 10.2.2.3
s=SDP data
c=IN IP4 10.2.2.3
t=0 0
m=audio 12568 RTP/AVP 0 8 9 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:9 G722/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=ptime:20
a=sendrecv
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
Thank you.
JL
