Watchguard firewall NAT
Discussion in '3CX Phone System - General' started by raldridge, Jun 24, 2008.
  1. raldridge
    Jun 6, 2008
    21
    Anyone using a WatchGuard firewall and can help with the correct NAT configuration to get the 3CX firewall test to pass? I'm been playing with the 1:1 NAT as described here but with no luck:
    http://www.corecom.com/external/livesecurity/1to1nat.htm
    I'm running the release version 6.
