wav file parameters
Discussion in '3CX Phone System - General' started by muaddib32, Dec 21, 2010.
  1. muaddib32
    Oct 16, 2010
    68
    What are the best parameters for the music on hold .wav files?
    Format (eg M/U law, PCM etc)
    Data, or Audio file?
    Sample Rate (eg 44100Hz, 16000Hz)
    Bit Rate (eg 16 bit, 8 bit)
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    It doesn't matter. They will be resampled to 8000Hz mono 16 bit. Therefore, this format is the most suitable
  3. muaddib32
    Oct 16, 2010
    68
    Great. Thanks for the quick response.
