Way to increase number of extensions?
Discussion in '3CX Phone System - General' started by jwardlaw93, Apr 12, 2018.
  1. jwardlaw93
    Mar 9, 2018
    14
    I'm sure this question has been asked before, so I apologize in advance, but some help would be greatly appreciated.
    I was wanting to see if there was any known way to go from 3 digit (XXX) extensions to 4 digit (XXXX) extensions.
  2. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    722
    122
    Unfortunately it is not possible. You will need to rebuild your 3CX server from scratch. If you dig around in old forum postings there are some that suggest it is possible with some hacking, but according to 3CX support it creates all kinds of problems down the road. Don't even try.
    jwardlaw93 likes this.
  3. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,095
    165
    As above, you need to start from scratch to be positive that the system will work correctly
  4. leejor
    10,737
    278
  5. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,311
    249
  6. leejor
    10,737
    278
    Or remind people to empty their voicemail box "before the change date", or risk loosing messages.
    craigreilly likes this.
  7. voiptoys
    Feb 13, 2013
    722
    122
    As craigreilly noted, the same is true of Recordings. Thankfully, 3CX is perfectly happy if you simply copy the correct wav and XML files (in the case of voicemails), or just wav files for Recordings, to the correct folders.
    Voicemails Path: C:\ProgramData\3CX\Instance1\Data\Ivr\Voicemail\Extensions
    Recordings Path: C:\ProgramData\3CX\Instance1\Data\Recordings
    Note for both voicemails and recordings, each extension has their own folder.
