Web admin interface
Discussion in '3CX Phone System - General' started by jsmack79, Jul 31, 2009.
  1. jsmack79
    Jul 31, 2009
    12
    Should i only be able to access this interface from the computer that 3cx resides on?
    i can't do 192.168.0.0:5481 from any computer, including the one it's on.
    it will only allow 127.0.0.1:5481.
    Is this normal?
  2. comresource
    comresource Member
    May 22, 2009
    303
    As far as I know the Cassini web service only responds to localhost requests.
    Someone correct me if I am wrong.
  3. jsmack79
    Jul 31, 2009
    12
    I'm almost positive I brought it up on my laptop right after I had installed 3cx.... and now it's not responding.
  4. jsmack79
    Jul 31, 2009
    12
    Update:
    I know for a fact that I could sit down on the 3cx machine and get to the web admin interface by typing in the full IP address.
    Now it only responds to localhost and 127.0.0.1. What did i break?
  5. comresource
    comresource Member
    May 22, 2009
    303
    Unfortunately I have never used Cassini due to the lack of ability to do SSL and Authentication and IP restrictions.
    And my comment earlier about remote connections must be wrong since phone provisioning and MyPhone obviously works with Cassini.
  6. houston
    Jul 21, 2009
    40
    Turn off the Windows Firewall, and any extra firewall your security software might have added. If it starts working, turn the firewall back on, and adjust firewall settings appropriately.
    The URL is the form of: http://xxx.xxx.xxx.xxx:5481 with the IP address (not localhost, and not 192.168.0.0) of the 3CX substituted in.
    I can say for sure that it works with Cassini on machines other than that which it is installed on. Working with it that way every day.
    After initially posting, it occured to me that your use of "192.168.0.0" MIGHT not have been as a bogus example address, but something you were actually attempting to work with. So I Googled it, just to have something to copy/paste and confirm I wasn't nuts. From About.com:
    .About 192.168.0.0
    Wednesday April 9, 2008
    | Definition | The IP address 192.168.0.0 is the start of the Class C private range. Broadband routers and other network gateways reserve this address to reference the private network. You should not attempt to set 192.168.0.0 as the IP address for your router or any computer as it will not function properly. Some routers are configured instead to use 192.168.0.1 by default that is the first usable address in the range.
    In other words, don't ever set any equipment on your network to end in ".0"
