web-based ip phone
Discussion in '3CX Phone System - General' started by gonzo__007, Feb 3, 2009.
  1. gonzo__007
    Nov 11, 2008
    44
    don't know if it exist...
    can I host a web server running a web based ip phone that act as an extention in 3cx ?
    I know it extist as a software that you install, just put the IP of 3cx, ext number and password and you can make calls. but does it exist web-based ?
    thanks
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,531
    69
    Check this topic: http://www.3cx.com/forums/web-voip-softphone-8242.html
