Web Client - Ability to forward VM to other extensions.
Discussion in 'Ideas' started by tsukraw, Aug 9, 2017.
Web Client - Ability to forward VM to other extensions. 5 5 7votes
5/5, 7 votes
  1. tsukraw
    tsukraw New Member
    Mar 9, 2012
    190
    7
    Title says it all.
    We run into this frequently when replacing legacy PBX units. They have the ability to forward voicemail from one extension to another.
    We have a lot of customers who phones at areas that to not have email. So voicemail to email is not a option.
    Would be nice if in the Web Client you could click the voicemail and there would be a option to Forward to Extension button.
    Jeremy Bero and architechture like this.
