Solved Web client Adding contacts
Discussion in '3CX Phone System - General' started by neville, Aug 5, 2017.
  1. neville
    neville New Member
    Apr 23, 2012
    208
    34
    is there a way to add a new contact directly from the webclient contacts tab? You can from calls screen.
    Chuck
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,462
    355
    Hello @neville
    You can add a contact from the personal tab of the web client to your personal contacts. To be able to add a contact in the company contacts the extension need to have the right "Can manage the company phonebook" enabled from the management console.
    XanthiZ likes this.
  3. neville
    neville New Member
    Apr 23, 2012
    208
    34
    I was missing the add button. Cleared my cache and it showed up. Works now. Thanks for the quick response.
    Chuck
  4. YiannisH_3CX
    May 10, 2016
    5,462
    355
    Glad to hear the issue is resolved :)
