Solved Web Client API
Discussion in '3CX Phone System - General' started by Schrodz, Aug 7, 2017.
Tags:
  1. Schrodz
    Schrodz New Member
    Apr 21, 2017
    100
    14
    How would we connect to the new web client API?
    The "Record" button only works in the web client API. (Pause recordings) We want to create a button that is larger that sits in the system tray.
    We have our own developer but just need pointing in the right direction..
    jed and StefanW like this.
  2. StefanW
    Jun 2, 2009
    1,216
    88
    Hey,
    for now you must hold on a bit until we moved some of the API calls to the server side and with this into the web client. At current we dont have an exposed API for the web client.
  3. Schrodz
    Schrodz New Member
    Apr 21, 2017
    100
    14
    Thank you for your reply. When will you enable the Record button working on the client to pause recordings?
    At the moment. It only works on the web client.
    Dan
  4. StefanW
    Jun 2, 2009
    1,216
    88
    SP1 of 15.5 will add this to the 3CXPhone, for IP Phones we can not do it at current...
  5. Schrodz
    Schrodz New Member
    Apr 21, 2017
    100
    14
    We have SP1 of 15.5. Still does not work on a 3cx phone.
    Dan
  6. StefanW
    Jun 2, 2009
    1,216
    88
    u have to download the new 3CXPhone separate as it is not pushed as part of the beta
  7. Schrodz
    Schrodz New Member
    Apr 21, 2017
    100
    14
    Stefan, you absolute legend. Thank you.
    StefanW likes this.
  8. Silly English Kniggit
    Sep 13, 2017
    220
    84
    Hi @StefanW
    Will this API be published at some point? We have several use cases where we want to interact with the API, not the front end GUI.
    B.Fluehmann likes this.
  9. StefanW
    Jun 2, 2009
    1,216
    88
    At current I can not commit to anything. What I can say is that with the next version the PBX can speak in such a form already with the webclient. However at the moment all is private API. Sorry to not be more helpful at present.
