Web Client Query
Discussion in '3CX Phone System - General' started by Schrodz, Jul 6, 2017.
Tags:
  1. Schrodz
    Schrodz New Member
    Apr 21, 2017
    100
    14
    We are a large resort and we do not have phones for each user. We want the users to be able to use the web client, but they will not have their own individual extensions.
    For example: We have an extension called "Arrivals1."
    Can we automate it, so whoever logs in to the PC that is next to the phone "Arrivals1". Logs into the phones webclient as the user Arrivals1 without having to enter a username and password?
    Can it be done via scripting and the username and pass are in the script?
    Dan
  2. aisonet
    Jan 25, 2013
    10
    Yes, most likely you could script this. I already know that you can get a chrome window and then a chrome tab, from there you would just have to auto fill out the form and submit it with the login info.
  3. Schrodz
    Schrodz New Member
    Apr 21, 2017
    100
    14
    Hmm,
    When I try to script it, I get a "Bad Gateway" error, if I clear the username and password and enter it manually it lets me login.
    Issue is, all the front desk staff have their own individual login so storing passwords in Chrome wouldn't work as that is per user. They move around different departments.
