Solved Web client uses wrong web meeting URL
Discussion in '3CX Phone System - General' started by PhatPanda, Sep 21, 2017.
  1. PhatPanda
    Aug 26, 2015
    58
    The native fat client correctly takes you to the external 3cx webmeeting URL, ie https://xxxx.3cx.net/webrtc/etc, but our web client simply redirects to our internal non secure URL at http://host.domain.com:5000. I have a support ticket open (160841) but they are now blaming the issue on ports being open. We are on 15.5 SP1, and all the necessary ports are open for the system to function normally and the system has been working fine since version 14. Ports should have nothing to do with the wrong link being used in the web client. Any ideas?
  2. PhatPanda
    Aug 26, 2015
    58
    Support pointed me in the right direction, and instead of using the suggested non-https link in the admin site, we changed to the https://site.com:5001/webclient and now things work.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    564
    Glad the issue is resolved
