web.config
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Oct 6, 2009.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    I have a custom assembly that needs to read a web.config setting. I tried putting it in the web.config in the ivr directory, but it didn'ts seem to read it.
    Which web.config file should I change so a custom assembly built with the VAD can read it?
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Are you trying to use an external code execution component to do this?
    How are you trying to read the configuration from your custom assembly?
  3. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    I have an assembly that is accessing a database through an entity framework model. It has to read the connection string from the web.config file of the web server. WCF services would have this same issue.
  4. VAD_Support
    Aug 6, 2009
    690
    Have you tried using a configuration file for your assembly? For example, if your assembly name is "Mylibrary.dll" you can use a configuration file named "Mylibrary.dll.config".
  5. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Yes, I did. But does that config file get deployed to the IVR web server with the assembly when the VAD deploys? I didn't think it did, but perhaps I missed it.
  6. VAD_Support
    Aug 6, 2009
    690
    No, it is not deployed, but I wanted to see if that fixes the problem. If it does, we can change the VAD to deploy that file too, if it exists.
  7. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    I will check and see.
