Web Server not reponding
Discussion in '3CX Phone System - General' started by Alain Russell, Sep 1, 2017.
  1. Alain Russell
    Sep 1, 2017
    Hi, we're a relatively new 3cx user and are seeing an issue where the web server stops responding and iOS softphone devices become unable to log in (all calls are failing at this point).
    I've attached some screenshots of the issue we see on the 3cx web interface, as well as what we see happening on the iOS devices in the video below.
    http://download.blackpepper.co.nz/230E2E1A0F3c
    This install has softphones only, no physical phones - I think the problem has only started since the last update but am unsure.
    Has anyone else seen this?
  2. agp
    agp 3CX Team
    Aug 19, 2015
    151
    22
    Hi @Alain Russell ,
    Is this a Windows or a Linux installation?
    Sometimes that error is shown during the update process where the services need to be stopped/restarted. If you try to access the system during that time you will get that error.
    1. Clear your browser's cache and try again.
    2. If a logical period of time has passed (for an update to be completed) and you keep getting that error, you might need to restart the 3CX Management Console + Database services.
  3. Alain Russell
    Sep 1, 2017
    Hi, there re no updates running at this time - we're seeing this 2-3 times a week currently and the only way to rectify the problem is a server restart - all incoming calls are failing so it's not related to a browser cache..
    Install is Linux appliance running the latest version (we didn't actually get this problem on the earlier version from memory)
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,452
    541
    What version are you running exactly and what are the specs of the machine? Do you have sufficient resources for your installation?
    Also when the issue occurs try to SSH into the machine and check which services are not running.
    To do so please type service 3CX* status
  5. Alain Russell
    Sep 1, 2017
    Thanks, current version is: 15.5.3849.1 (15.5.5)
    Server is 1x CPU, 2GB Ram, SSD disks (running on VMWare) - Load and CPU are always low when the web server stops (checked on the command line)
    Typing the command I see:
    root@phone:~# 3CX* status
    -bash: 3CX*: command not found
    Thanks.
  6. YiannisH_3CX
    May 10, 2016
    7,452
    541
    How many extensions and clients do you have? And how many cores are there in the CPU?
    The command is:
    Code:
    service 3CX* status
  7. Alain Russell
    Sep 1, 2017
    Single core on the VM currently - 7 extensions only (all softphone). Next time we have an issue I'll check the status - thanks.
  8. daneke
    May 8, 2017
    46
    Sometimes you just need to close the browser and return
