Web service post with void function calls
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Oct 6, 2009.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    I thought I'd share, I don't know if this was intentional or not, but as I was having difficulting using the web service component (I was getting an error regarding no root element in the xml) I discovered that you can't call a function that has a void return.
    Since I wasn't trying to read any data back from the web service, I couldn't figure out why I was getting an error regarding the return data.
    Once I simply had the webservice return "OK" or "ERROR", then the IVR didn't complain about it any more.
    This was a SOAP based web service.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Thanks for your feedback, maybe this is a bug in the VAD, we'll verify it.
    As a workarround, you can use the Web Interaction component to do that. You can invoke your web service sending a POST request, and the response can be ignored.
  3. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Well, if I simply return anything at all it will work. So I just return an "OK" string and it won't crash.
  4. VAD_Support
    Aug 6, 2009
    690
    Yes, if you can change the web service, maybe that's the best approach. But if you can't change it, you can use the web interaction component.
