Webcam won't work from 3CX myPhone to 3CX myPhone
Discussion in 'Windows' started by Robin Goosen, Oct 3, 2012.
  1. Robin Goosen
    Oct 3, 2012
    My company is using 3CX to make VOIP calls using a VPBX.
    We would like to use de webcam functionality but for some kind of reason we are not able to see each other on the webcam.
    We can see ourselves though.
    Could someone try to help fix my problem.
