Solved Webclient conference
Discussion in '3CX Clients' started by DovydasJ, Nov 8, 2017.
  1. DovydasJ
    Nov 17, 2015
    17
    13
    It seems I can't add participants to conference. No matter it's audio or video, there is no such a field. Is it should be like that?
  2. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    241
    12
    If you choose Google to be you calendar (Look on the bottom of the conference) then when you hit create Google Calendar should pop up on another tab.
    From the Google Calendar you should find a field where you can add your Guests/Participants or any other conference setting.
    Thank you
  3. DovydasJ
    Nov 17, 2015
    17
    13
    Thank You Marios! Pop up was blocked, so it don't worked. I also didn't know that after that should open new window. Thanks!
