Webclient - Disable popups when incoming or outgoing call is received
Discussion in 'Ideas' started by flexible3, Sep 7, 2017.
  1. flexible3
    Feb 9, 2016
    Apparently it is not possible to disable a popup from an incoming / outgoing call in the webclient. I just don't want to see this. Can this be changed?
    Yours faithfully,
    Tom Van de Putte
