FredyWenger
- Joined
- Jun 18, 2018
- Messages
- 102
- Reaction score
- 4
I have problems (once again >- not the first time) that the local passwords (local access with the webclient) to two new added Yealink T46s where changed thru 3cx to an unknown value, searched for similar problems and thereby found this thread:
https://www.3cx.com/community/threads/webclient-password-after-upgrade.59021/
As the tread is closed already (for whatever reason?!?), I had to post this new thread to be able to write something to it...
It’s a very bad idea to remove the "eye icon" and make the work of all admins harder...
The console is for admins not for end users...
If somebody have the console password, he should be able to see all passwords in the console and...
...if he can see the password, if he export an extensions list the solution is not more secure..
So please add the “eye” icon again and make the admin life easier and not harder by every update...
Regarding the local password for the webclient, there definitely is a problem (I don't know where exactly, maybe it's also a problem with the provisioning / update of the set password to the local device (I already have re provisioned and rebooted the devices multiple times and the password showed in the console don't work).
I now have to do a factory reset to the devices, although they are configured and work, as I'm not able to access it via browser as not the in the console showed password is set and I don't know, which password is set actual.
