Webclient phonebook improvements
Discussion in 'Ideas' started by B.Fluehmann, Dec 6, 2018.
Webclient phonebook improvements 5 5 2votes
5/5, 2 votes
  1. B.Fluehmann
    Jan 7, 2017
    16
    The usability of the webclient search function is very limited because:
    - One line per contact and number without showing the type of number.
    - Missing company name.
    As an example I have created two contacts:
    Contact 1:
    FirstName: John
    LastName: Doe
    Company: ACME A
    Contact 2:
    FirstName: John
    LastName: Doe
    Company: ACME B
    As you can see, the example results in a list of 4 identical lines with different numbers.
    Impossible to tell if this is one contact with 4 numbers, 4 contacts with 1 number each
    or any combination.
    Most of the problems could be solved by either
    - Add company name and number type to the entries or
    - Show address objects (like contact search) with company-name
    For companys with multiple equally named employees, please add the following fields
    This applies to both contacts and extensions:
    - Departement
    - Short/Nickname
    To avoid compatibility issues, add an option to select the displayed contact fields or some
    predefined schemes.
    Regards
    Bernhard
  2. Andi Moser
    Aug 2, 2018
    19
    Would be great.
