Webclient voicemail greetings. record from different phone
Discussion in 'Ideas' started by frog, Aug 29, 2017.
Webclient voicemail greetings. record from different phone 5 5 2votes
5/5, 2 votes
  1. frog
    Sep 22, 2015
    22
    could we have the greeting popup have the drop down to select a phone to record from. in the same way as you get from the management console.
    ie we have a company voicemail user with no phone. If they want to change the greeting they have to get console management access for that user and then record. If the webclient had a drop down on the "Record Media prompt File" window that would be much easier.
    Thx.
    Chris
  2. accentlogic
    accentlogic New Member
    Nov 14, 2013
    161
    66
    If an external number can be dialed, rather than just an extension, that would also be helpful. Especially during emergency announcement changes by remote staff who don't have a provisioned softphone.
  3. frog
    Sep 22, 2015
    22
    Yes also good idea.
    accentlogic likes this.
