Webclient Webmeeting Option from Phoneboook...
Discussion in '3CX Clients' started by Randall, Feb 16, 2018.
  1. Randall
    Mar 27, 2017
    30
    17
    I'm trying to figure out the usefulness of the Webmeeting link in the attached image. It appears that it allows user A to start a Webmeeting as the user who's Webmeeting link was clicked. Is that correct? If so, how does someone else connect to that Webmeeting, besides copying and pasting the link from the spawned Webmeeting. It feels a bit superfluous.
