Webmeeting Access Issue/Concern
Discussion in '3CX Phone System - General' started by Cory P, Sep 22, 2017.
  1. Cory P
    Jan 10, 2017
    14
    Using 3cx Version 14, we have in the past been able to use Webmeeting and some users had access some users didn't.
    Well, recently, we went to delete a user and their extension from 3cx, but when we would try, the extension was still assigned a webmeeting account.
    We would then go to the Webmeeting menu section, and typically uncheck the extensions active account. But now the Webmeeting tab is completely grayed out and we are unable to select/deselect any of the extensions, which means we are unable to update or even delete any of the extensions we have.
    If anyone has any knowledge why this might be the case, help would be appreciated.
    Let me know if you need additional information.
    Thank you,
    Cory
  2. Brian Cross
    Brian Cross New Member
    Jul 26, 2017
    109
    27
    3cx licensing current?
  3. MMDTerry
    Jan 11, 2017
    21
    Yep mine is the same way, I noticed earlier when i could not start a web meeting. Im hoping its just an outage and they did not discontinue support for v14 users.
  4. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    You need to upgrade to v15.5, webmeeting is intentionally disabled in v.14 by 3CX from Sep. 1st, 2017. Probably somebody could say why.
    Regarding seeing extensions in webmeeting menu, all extensions which have emails configured are showing into this menu, regardless it is disabled
    #4 sip.bg, Sep 23, 2017
  5. VICSD
    Oct 11, 2017
    Same problem. We are using v14. Everything worked fine until they disabled Webmeeting. It really screwed up with our plans and added headache and frustrations as we were not ready yet to upgrade.
    So the problem is that you have to uncheck each profile from webmeeting before changing e-mail or deleting that profile. Or you have to disable webmeeting at all. If your webmeeting was enabled as of September 1st, 2017, then you cannot anymore make e-mail or deletion changes to your profiles. The reason is that in your system webmeeting is stuck as enabled but now is dysfunctional. You cannot even disable it and you cannot uncheck any profile. What 3cx did is really frustrating to us.
  6. Tripp
    Jul 10, 2017
    8
    Is there a work around to disable webmeeting system wide so we can delete and manage the extensions?
  7. sip.bg
    Nov 7, 2016
    704
    219
    probably only editing the backup file (.xml) and restoring from it, deleting some extensions, requires detailed understanding of the .xml file contents
  8. StefanW
    Jun 2, 2009
    1,210
    84
    yes you can solve this without restore, guide comes just in a second to you...
  9. 3CXNP
    3CX Support
    Apr 25, 2014
    42
    Just to clarify, the recommended fix for this is to upgrade your PBX to Version 15.5. The webmeeting functionality can then be restored, and the unlinking of the extensions, resulting in the ability to edit the extensions, as the webmeeting platform in Version 15/15.5 functions differently to how the Version 14 webmeeting platform functioned.
    The modification given herein, should only be done in cases where an upgrade is not possible at the time being.
    Also, this fix should only be undertaken at your own risk, and we cannot accept responsibility for an unsupported version not functioning after this fix is applied. As always, before performing and configuration changes, take a full backup of your PBX.
    Open your 3CX Management Console (Version 14)
    Go to "Troubleshooting"
    Go to "Parameters"
    Delete the parameter "WEB_MEETING_PORTAL"
    You will then need to enter the DN_Properties of each extension and delete the following parameters for each extension:
    WEB_MEETING_MD5PASSWORD
    WEB_MEETING_PASSWORD
